Revit Architecture
Revit Architecture
Active Member
sburke
Message 1 of 4 (632 Views)
eTransmit 2013 error connecting to Revit Server host
632 Views, 3 Replies
07-31-2012 09:54 AM
I receive this error when testing eTransmit for Revit 2013. "etransmit encountered an error while trying to contact the server". Oddly, it is only a problem with on host, and not the other. Anyone else experience this issue?
Product Support
fernanda.firman
Message 2 of 4 (600 Views)
Re: eTransmit 2013 error connecting to Revit Server host
08-06-2012 11:44 AM in reply to: sburke
Have you reebooted the server?
Does the server have both Anonymous and Basic authentication enabled?
If so, please try disabling Basic authentication and check if the issue goes away.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Active Member
sburke
Message 3 of 4 (594 Views)
08-06-2012 12:26 PM in reply to: sburke
We enabled Anonymous Authentication, which seems to have solved the issue. Thanks.
New Member
josh3ber
Message 4 of 4 (467 Views)
11-16-2012 07:29 AM in reply to: sburke
I was using e-transmit without any problems in Revit 2012 on a Revit server. My office recently upgraded to Revit 2013 and now I'm getting errors like you guys. I'm working on a large high rise project with mutiple central files that are shared weekly with consultants and not having e-transmit is making my life much more difficult. No one has a solution?
Post to the Community
New Post
Need installation help?
