I receive this error when testing eTransmit for Revit 2013. "etransmit encountered an error while trying to contact the server". Oddly, it is only a problem with on host, and not the other. Anyone else experience this issue?
Have you reebooted the server?
Does the server have both Anonymous and Basic authentication enabled?
If so, please try disabling Basic authentication and check if the issue goes away.
I was using e-transmit without any problems in Revit 2012 on a Revit server. My office recently upgraded to Revit 2013 and now I'm getting errors like you guys. I'm working on a large high rise project with mutiple central files that are shared weekly with consultants and not having e-transmit is making my life much more difficult. No one has a solution?
