eTransmit 2013 error connecting to Revit Server host
3 REPLIES 3
sburke
1047 Views, 3 Replies
I receive this error when testing eTransmit for Revit 2013. "etransmit encountered an error while trying to contact the server". Oddly, it is only a problem with on host, and not the other. Anyone else experience this issue?
3 REPLIES 3
fernanda.firman
in reply to: sburke
Have you reebooted the server?
Does the server have both Anonymous and Basic authentication enabled?
If so, please try disabling Basic authentication and check if the issue goes away.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
sburke
in reply to: sburke
We enabled Anonymous Authentication, which seems to have solved the issue. Thanks.
in reply to: sburke
I was using e-transmit without any problems in Revit 2012 on a Revit server. My office recently upgraded to Revit 2013 and now I'm getting errors like you guys. I'm working on a large high rise project with mutiple central files that are shared weekly with consultants and not having e-transmit is making my life much more difficult. No one has a solution?
