error with Link cad, cannot reload file
1 REPLY 1
smoffa
888 Views, 1 Reply
Hi I am ussing Revit 2014
I am having problems linking my cad file is my drawing.
I recently experienced a network failure, wich caused me to restorem my link.
most of my links seem to work expect two of them i keep getting this error "A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing."
when i try to either relord or re-link the cad file.
I have try to rename the file but i still won't work.
Does anyone have any idea?
1 REPLY 1
LisaDrago
in reply to: smoffa
Hello and Welcome to the Discussion!
Have you run an audit on your file?
You can do this as you open the file. I have attached an image for reference.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
