Revit Architecture
Revit Architecture
Valued Contributor
tfisch86
Message 1 of 2 (377 Views)
Error when trying to export to navisworks? (.nwc)
377 Views, 1 Replies
08-04-2012 09:24 AM
I am trying to export some Revit models to .nwc for use in navisworks.
I have been getting some odd errors, sometimes I get them, sometimes I don't. Sometimes I will get the error, close the program, re-open, and it will export fine. Other times I try that and still get the same error with no luck.
I need to get these into .NWC files, and doing it from Revit holds more infomation than trying to import them in Navisworks.
Attached is a picture of the error message Revit is giving me... HELP!
Gyvven
Message 2 of 2 (306 Views)
Re: Error when trying to export to navisworks? (.nwc)
08-20-2012 08:53 AM in reply to: tfisch86
I've been having the same issue. I'm using Revit MEP 2012 and exporting to Navisworks 2013. Closing and re-opening the model sometimes fixes the problem, sometimes not. I usually need to export multiple disciplines from each model and the first one generally works fine but the second will get the same error you list. Lately it's been happening any time I try to export, this wouldn't be so bad except that the files take better than 10 minutes to open.
The .log file only contains the following lines:
System.ObjectDisposedException: Safe handle has been closed
   at System.Threading.WaitHandle.WaitOneNative(SafeHandle waitableSafeHandle, UInt32 millisecondsTimeout, Boolean hasThreadAffinity, Boolean exitContext)
   at System.Threading.WaitHandle.InternalWaitOne(SafeHandle waitableSafeHandle, Int64 millisecondsTimeout, Boolean hasThreadAffinity, Boolean exitContext)
   at NavisWorks10.LcRevitExportCommand.Execute(Application application, String& message, ElementSet element_errors)
