If you are using 8.1 you can try opening the file using the audit checkbox
in the open file dialog. This may clear up the issue as well, without
sending it to us.
Jeff Hanson
Autodesk Product Support
Building Solutions Division
Manchester, NH
_____________________________
wrote in message news:4950258@discussion.autodesk.com...
You aren't doing anything wrong, there is something in your project that is
failing when the change is occuring. You need to send you file to support
for them to fix it. While you are waiting, look at in place families or
sweeps or other objects that would be affected by the change.
