New to Revit. Trying to create a topo from 3D contour data brought in from AutoCAD. When I click on the green check I receive an error message "The surface must have at least three distinct Points. And it doesn't create a solid surface. The only solution I saw from previous post is that I need to import my file in "metric" but I thougth that cant be correct. Hope someone can help. Thanks. Michael May
Depending on how the file was created its very possible that the solution is to set Metric as your import setting. I'm assuming this is the post you say: http://forums.autodesk.com/t5/revit-architecture/creating-toposurface-from-dwg-import/m-p/5118296#M7...
Without the AutoCAD file I have no way of knowing, but if setting the units to Metric works will that work for you?
Thank for posting.
After 8 years i've got the same situation. Just for the record, if some deseperate soul has the same error message.
The problem must come from the DWG file .
In mi case, the topography wasn't made of "curve lines" with elevation, but polygons that revit didn't recognize as topography.
I'll leave the screenshot below.
