When trying to start the revit 2014 I get an error message which says you can not start the application, the parallel configuration is incorrect. Consult the event log or use the application sxstrace.exe tool command line for more details. I tried to launch with administrator rights and compatibility and the problem still persists, someone might know to be the problem?
Thank you for posting.
This issue have been addressed in the following links:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095878&linkID=9241177
http://forums.codeguru.com/showthread.php?444448-quot-Side-by-side-configuration-is-incorrect-quot
It is showing under the 3ds max but this is a windows message, not specific to Revit.
Hope that helps.
