Error Message ????????????????????????
5 REPLIES 5
395 Views, 5 Replies
Hi all,
I am getting an error message and now I can not save my work. I have attached a copy of the screen print showing this message. What is causing this and how can I fix this? Any help will be greatly appreciated and thanks in advane.
bahardman
5 REPLIES 5
You can open the same two projects on one system, but
the second project opened isn't going to be able to save
anything until the first one is done with its business.
That's only fair.
Thanks for the reply, but there are no other copies of the drawing opened. So I can't figure out what the problem is.
you should try to 'copy and paste' the file from one location to another and then try to open it.
let us know the results, plz.
Thanks parveen, that solution worked great.
good to know. 🙂
