error message
2 REPLIES 2
439 Views, 2 Replies
error message
I have installed Revit Architectural 2012 and when I press "New" I get the following error message "Attempted to access Default AUSENU.rte past its end". How can this error message be removed and can progress into a new file?
2 REPLIES 2
You need to tell Revit where to look for that template.
loboarch
A "past its end" error typically indicates a file error of some kind.  You will have to resort to a back of that RTE file or re-create the template file.  The original one you are attempting to create a project from has been damaged in some way.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
