Error message when importing AutoCad files into Revit
2 REPLIES 2
780 Views, 2 Replies
I just installed Revit. I had already made the plan of the structure I want to model in AutoCAD, but I am unable to important the Plan into Revit. Every time I try linking the file, an error message pops up saying that the AutoCAD file name has unsupported characters and that it can't be use. But, the file name doesn't have any of these unsupported characters. I've tried it with many other AutoCAD files and have tried both linking and importing, but the same prompt comes up each time. Do I need to re-install revit? Or save my AutoCAD files a different way?
2 REPLIES 2
filipefrancisco
Try to save the DWG in a lower version, or change the type of fonts in DWG
You dont need to reinstall the revit....
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
in reply to: filipefrancisco
Just tried it with a 2004 DWG file, and the same message popped up when I tried to select the file. I had also deleted all the text from the file.
