Hi Guys,
Maybe you could help me with this. Im using Revit 2014 and im trying to put structural Column and beams and always show up this messages Please see attached. And when i cancelled my column disappear (i have no choice but just to cancelled it) because i cannot put it. Thank you
Have you isolated the two elements in question from the warning dialog to see if you can locate any overlapping boundary edges? You could either select the checkboxes and click Show, or you could note the Element ID numbers and go to Manage > Inquiry > Select by ID and enter them there. Once you see the elements, you could isolate them in your model to see if you can determine where the conflict is. It looks like it might be with the analytical boundaries for the floors, so I would make sure you have the Analytical Floors category turned on - I can't tell if you do or not from the screenshot.
