My line pattern properties says that a dot/gap cannot be smaller than 0.52mm!!! The ISO 128:20, requires, for a good ammount of line thicknesses, that the dash length that represents a dot, is far smaller than 0.52mm. Also gaps have to be a little bit smaller than 0.52mm in the thinnest lines.
Is Autodesk fixing this problem?
Hello and thank you for your feedback. This is a currently limitation in Revit. If you wish for this limitation to be altered or removed we recommend that you log a wish in the Product Feedback page which you can fin at the following location:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
The feedback received is always welcome by our developers and product managers for future improvement considerations.
Kind regards.
