Revit Architecture
Active Contributor
thomas4611
Message 1 of 1 (247 Views)
equally space windows
247 Views, 0 Replies
09-02-2012 03:37 PM
Is there a quick way to place windows equally between the walls of a room, without taking the room width, subtracting the total of the window widths and dividing by the # of spaces between windows plus the two spaces between the end windows and the wall.
If you set up a dimension string and dimension to the window centerlines and set an equality constraint that does not work because the spaces between windows will be less than the spaces between the end windows and the interior walls.
Need installation help?
