Here's how you do it. Click on the Dimension command, select the outer
wall, then select the window, then the next window, then the wall. So you
have 3 dimensions all grouped together. The 2 dimensions that are on the
outside are from the outer walls to the window are equal in
dimension...right? If so, click on the string of dimensions and go to
Properties, down to the bottom of the dialog box there's a Parameter called
Equality Display, change this from Value to EQ. Select this and OK out of
the box. Now you should have what you want. Make sure to padlock the equal
dimension.
wrote in message news:5548877@discussion.autodesk.com...
I did array the windows and lock the distance between eack window. What I
want to do is the wall distance from the exterior to the window frame equal
on both sides? So if the exterior wall changes moves or shrinks the outer
dimension will always keep the windows equal from the ends of the exterior
wall.
