I made some perspective views of a test project and placed them on a 24x36 sheet. The views however are too small, and I can’t seem to figure out the best way to enlarge them. I’m sure it’s simple, so can someone please guide me to maybe a tutorial?
Phil
Solved by L.Maas. Go to Solution.
It is easy, but indeed not straightforward.
When in the view click the border of you perspective view. Then select size crop.
Make sure you select scale (Not field of view). Increas the width (or height). On your sheet the view will increase in size
Louis
Please mention Revit version, especially when uploading Revit files.
