Hi, I have a problem with the monolitic stairs, that not connect correcty with the floors. My stairs are concrete, so they should be a beam continuouswith the floors. I have try all the options but noting seems to work. I'am attaching the picture of what I get and what I'd want to have.
Any ideas?
Thank you very much,
Silvia
can you post a screen shot of the properties of the mentioned stairs for us to have a look?
A partial workaround to this issue is to use landings. Either automatic ones or sketch ones.
Once you have the landings, join the floor and landing.
Lines will still appear in plan seperating landing with floor, but then you can use invisible lines to hide the lines which have been cut to size by joining process.
This doesn't work for the start of stairs since the landing can't be created there.
Thank you, your suggestion worked very well for the upper end of the stair, I am thinking how to work around the beginning.
But... I do not have any invisible lines. That is new! How do I use them?
Silvia
Thank you!! I am attacking the properties, I hope you could see where is my mistake.
Silvia
If you use keyboard shortcut "LW" you will be able to override any existing linework or edges of objects. In the tab menu choose a linetype from your line styles. Choose <invisible lines> and click away.
