Endcaps in Revit
9 REPLIES 9
Message 1 of 10
petervanko
3901 Views, 9 Replies
Endcaps in Revit
Where is the control over wall materials when they terminate in unconventional ways? Editing wall joins has much limitation?
And how about opening endcaps? In ADT I was able to apply a custom endcap to openings made by windows, doors, etc. For instance, here I could control the gyp wrapping the entire opening, and butting the windows and doors (see attached file). Similarly, openings would wrap.
Do I need a detail component in the window family?
9 REPLIES 9
Message 2 of 10
sbrown
in reply to: petervanko
Look at the help files on families/walls for "wrapping at inserts" Basically in the window/door family, you add a ref. plane in plan and select it, and under its properties there is a choice for defining it as where finishes wrap to. then in the wall properties there is a choice for if you want layers to wrap and if so at exterior/interior.
Message 3 of 10
This is a main problem to me. Over here in Belgium (and the rest of northern
Europe) we need the opening in the exterior components of a wall to be
smaller than the opening in the interior wall structure. This is possible
with ADT endcaps but not with "wrappings" in Revit. Even the "edit cut
profile" dousn't seem to be a (2D only)solution.
I hope to find a solution to this, if not this program seems to be useless..
wrote in message news:5054186@discussion.autodesk.com...
Message 4 of 10
It is possible, see attach, this is one window family
Look in
http://download.autodesk.com/WebPub/revit/localiser_nl/setup.exe
This is a link to the BE / NL localiser
Look in the Belgian content Windows / Doors
good luck
Nic M.
"RafVT" wrote in message
news:5057111@discussion.autodesk.com...
Message 5 of 10
No attach??
Second attempt
"Nic M." wrote in message
news:5057124@discussion.autodesk.com...
Look in
good luck
Nic M.
smaller than the
Message 6 of 10
petervanko
I have the opposite problem...I typically need the outside opening to be smaller than the inside. Usually this is because I have GWB returning to the window frame.
This may be the first thing ADT does better...LOL.
Message 7 of 10
That shouldn't be a problem.
Open a new family based on a windows template
Remove the "Opening" (you need to TAB to get there)
Create Void forms as you like and use the "Cut geometry" to substract them
from the wall.
You can make any condition you like
Nic
wrote in message news:5057877@discussion.autodesk.com...
the window frame.
Message 8 of 10
Is this only possible with windows?
I wanted to use a storefront curtain wall but there the trick with void
forms isn't possible i think. Do you think making an opening with an empty
window family and putting a cutain wall in the opening is the only (but far
from elegant) solution?
thx
Raf
news:5058159@discussion.autodesk.com...
from the wall.
Nic
the window frame.
Message 9 of 10
petervanko
This post satisfies all of my concerns. I was easily able to duplicate what you instructed, as well as add instance parameters for the returns so that if the frame width changes, so can the return!!! ADT sure can't do that...
Message 10 of 10
Helaas, no such option for curtain wall.
I also used the "empty window", it works. You can lock the curtain wall to
the some ref planes defined in the window family.
In some accasions I just draw a small piece of exterior wall and lock it to
the main wall.
Nic
news:5058508@discussion.autodesk.com...
thx
Raf
from the wall.
Nic
the window frame.
Rail Community
