Revit Architecture
Revit Architecture
Active Contributor
1 Kudo
Post 1 of 5
Enableing Surface Nodes on In Place Mass
601 Views, 4 Replies
10-07-2012 01:29 PM
Activating nodes under surface of the Surface Representation panel under Modify/Divided Surface Panel shows nodes at intersections of U & V grids of an in-place mass.  Is it possible to enable these nodes so that the surace can be modified by manipulating these nodes?
Peter
*Expert Elite*
363 Kudos
Post 2 of 5
Re: Enableing Surface Nodes on In Place Mass
10-09-2012 09:03 AM in reply to: pete
No. Nodes cannot be selected individually to edit the surface.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Contributor
1 Kudo
Post 3 of 5
10-11-2012 01:01 PM in reply to: Alfredo_Medina
How can I model an object-in this case a concrete slab and modify only the top surface?  Modifying a slab using the conventional tools in Revit -like adding a point and changing its elevation to be out of the plane of the surface also affects the soffit or bottom of the slab.  I want to  manipulate only the top of the slab.  Can I do it somehow by creating an in-place mass?
Thank you,
Pete
*Expert Elite*
363 Kudos
Post 4 of 5
Re: Enabling Surface Nodes on In Place Mass
10-11-2012 02:32 PM in reply to: pete
Floors can have variable layers. It's one of the type properties of the floor.
Active Contributor
1 Kudo
Post 5 of 5
10-15-2012 11:45 AM in reply to: Alfredo_Medina
If floors have variable layers how does one prevent changing the surface of one layer from affecting the other layers?  How does one isolate each layer so that it is not affected by changes in the surface of another layer?   e.g.- does putting a drain in the top layer of a concrete floor not affect the other structural layers in the floor?
Post to the Community
New Post
