Hi!
I have a curtain panel/system panel problem:
I want to create an empty panel. Without any material - no glass or anyting.
If you create a curtain wall: And go to its properties: Edit Type: Curtain panel. There you should have an option to choose Empty? Or should you? I have seen that option in "other guys program". 😄
How can I create curtain/system panel or edit the family to empty one?
And where on earth are those Curtain Panels and System panels actually??
In file manager I have not found them (the family files)? Nor the Windows search function does not help? But they must be somewhere?
If I choose None to Curtain panel, should it be totally empty? I think it should, but I have managed to get glas into it too!
;-D
Thank you, if you can somehow help me, this issue is too complex to me! ;-D
Best wishes
Matti Kettunen 🙂
Solved by Alfredo_Medina. Go to Solution.
From an elevation view, make a window selection around one of the panels. Use Filter (the funnel icon at the lower right corner of the interface) to select only the curtain panel; close the filter window. Then Edit Type > Family : Empty panel , Type : empty.
If you do these steps and you still cannot change the panel, probably the curtain wall is of the "storefront" type. Change it to the "curtain wall" type and try again.
See illustration.
http://seek.autodesk.com/product/locale/adsk/revit/families/arch/empty/Revit_ARC151
This is an easier way
Where will I find this now with the switch over from Seek to BIMobjects? The old Seek links do not work.
Seems we can find the "Empty" panels in the Commercial Template. I was able to copy it over and utilize it in our template.
