Hi All
I embedded a label (Generic Annotation) into some families that is only shown on plan views. Is there any Label that can be shown in the Room elevation views. I attached a simple familie with a label. Thanks
Solved by Alfredo_Medina. Go to Solution.
No, but since you entered also "GH" for the keynote parameter, in elevation views, you could annotate the family with a parameter. With no box and no leader, the keynote looks exactly as the label.
