Hi Users,
Anyone know the fix for this error?
Could not access project information (probably because it does not exist).
Exception:
System.NullReferenceException: Revit project information does not exist.
at ElumTools.SharedParameters.get_DocumentVersionParameter(Document Doc)
at A.c26d617ccf2d9e9b6e6ace6cf42a27d1d.ce855a696e8bfaebeac34d096e86e4baf(Document c3d19f489e7dc39892e3ea723c8e3d0d3)
at A.cccec69d5e878300985af751b0ccacba8.cd416900a5482f8d59b9290480d24e10b(Document c88e37568945914a72b1ef05f10d71e35)
ElumTools 2015 Release 3 (2015.3.0.2)
ElumTools (2015.3.0.2)
C:\ProgramData\Autodesk\Revit\Addins\2015\ElumTools.bundle\ElumTools.dll
I installed Elum Tools yesterday to my 2015 Revit software, did one corridor calculation, shut down the machine, and then got this error today in my local copy file. I finally synced to the central model, but the error won't go away. Advise?
Thank you!
Sincerley,
michelle
In the past, we have seen Elum Tools corrupt the Project Information element in the Revit file. The fix is to open a previous version of the file with the Project Information intact, and use Transfer Project Standards to copy the Project Information from the old version to the new version.
Hi There,
I tried transfer of project standards and now have this error:
Could not store project settings entity on element.
Exception:
Autodesk.Revit.Exceptions.InvalidOperationException: Writing of Entities of this Schema is not allowed to the current add-in.
at ?A0x2696a60f.ESEntity_constructor(Schema schema)
at Autodesk.Revit.DB.ExtensibleStorage.Entity..ctor(Schema schema)
at ElumTools.ExtensibleStorage.set_ProjectSettings(Element element, ProjectSettings value)
RevitAPI (2015.0.0.0)
C:\Program Files\Autodesk\Revit 2015\RevitAPI.dll
Thank you -
Sincerely, mie
Oh, and this when click on a space to do a calculation
ould not complete ElumTools command: AddCalcPointsSpaceCommand
Exception:
System.NullReferenceException: Object reference not set to an instance of an object.
at (Object )
at A.cdb5ec3b5400dbadf4f65d30038f385e4.c0980ba9e65f355275040014e6b7a37b9(Object c1c26314621b5069a778a18a667bfdd75)
at ElumTools.CalcPointsFamilyInstance.Create(Element element)
at A.c78b33a66fbf022196181920515d20a46.ce855a696e8bfaebeac34d096e86e4baf(Element c742964f37b3b0c31f66443cbc5af4263)
at ElumTools.AddCalcPointsSpaceCommand.Execute()
at (Object )
at A.c249050884a7305b6a3621c7944094ad7.c0980ba9e65f355275040014e6b7a37b9(Object c1c26314621b5069a778a18a667bfdd75)
at ElumTools.ElumToolsCommand.c142a1bdf52441deaa22077810e5f0ec7(String& c6c21068261e21189d4e1b9d3a9183052, ElementSet cf277011a2bb655d06768164c9de509c0)
at ElumTools.ElumToolsCommand.c3629a6b664445465162d27066828e342(ExternalCommandData c6d0d8afff2f544a0846f36b604653ab4, String& c6c21068261e21189d4e1b9d3a9183052, ElementSet cf277011a2bb655d06768164c9de509c0)
at ElumTools.ElumToolsCommand.c3ea6116566a3e629e15273d303779ee9(ExternalCommandData c6d0d8afff2f544a0846f36b604653ab4, String& c6c21068261e21189d4e1b9d3a9183052, ElementSet cf277011a2bb655d06768164c9de509c0)
at ElumTools.ElumToolsCommand.Execute(ExternalCommandData commandData, String& message, ElementSet elements)
From the errors, it looks like Elum Tools is having trouble writing to part of the Revit database. I would uninstall Elum Tools, use Transfer Project Standards to get the Project Informaiton back, and then reinstall Elum Tools.
If the behavior comes back, I would let Elum Tools know that the add-in looks to be corrupting the Revit Project Information. The following page has steps for doing this:
http://www.elumtools.com/docs/2013/Content/About%20ElumTools/Support.htm
Sorry for all the feedback - hopefully this helps you all track down the bug 🙂
ANother error, when purging a lighting family from the model -
Could not store calculation dependency entity on element.
Exception:
at ElumTools.ExtensibleStorage.set_CalculationDependencies(Element element, ProjectCalculationDependencies value)
While I have logged this issue with Elum Tools, I would encourage you to do the same since you can send them the file in which this is happening along with any other data they may need to resolve this issue.
Hi There,
I uninstalled the tools. Rebooted. Opened the file detached from central, and saved a new, detached copy on my local 'c' drive. Reinstalled the tools. Still getting the same error - advise??
Sincerely, .:mie:.
Michelle Neidiger
Edited by
Discussion_Admin
