Hi ,
I am beginner in using Revit.
I noticed that I don't have (ELEVATIONS) tab and also (elevation icon). See the picture. Also (Elevation Marks) in the window view are not exist.
How can I regain all these?
thanks
Jaf
Solved by Alfredo_Medina. Go to Solution.
Thanks for your fast response.
I tried your idea(view ---> Elevation) but no positive result. But in a sample drawing , (Elevations tab) is exist.
I tried to use a template, but what I found, that I don't have any template and library. See the attach picture (as example).
Is that to do with mistakes in installation process? or there are othere reasons?
thanks
Jaf
Probably, the installation did not finish properly, and you don't have templates?
But I don't understand why using View > Elevation gives "no positive result" to create new elevations.
The lack of templates can be fixed by finding the files and putting them in the correct folders.
Thank you for your responses. I solved it. It was mistakes in the installation.
hi,
good day, im having the same exact problem that you have, and canyou help me out with this? how did to solve it?
Thanks.
Karl
Hey, I had the same problem and I still didn't find the RIGHT answer, but you can solve it like I did by chance, go to Open => File examples (or sth like this sorry I have french version) and from the list you chose for example 'Arch Link Model'.
This file has already everything in place including elevation marks etc., it may be a better way to start with. Maybe it's possible to write it down as a template.
Good luck,
M.
