Elevation Views In Revit 2013
1 REPLY 1
mohamed.hakam
259 Views, 1 Reply
I can not find the Elevations view in revit 2014 when I open a new file while it is in the program's template files.
Where can I get them to be shown as levels also are limited to only level 1.
Thank you
1 REPLY 1
BIMAbhi
in reply to: mohamed.hakam
You can put the Elevation view as per your requirement side from View > Elevation tab in Revit. After doing this you can see the elevation view in the Elavation section of the Project Browser DB.
Thanks & Regards
BIMAbhi
Rail Community
