elevation target arrow head for spot elevation
2 REPLIES 2
jledgewood409
1139 Views, 2 Replies
I would like to use an elevation target that is filled as opposed to the open (unfilled) elevation target that is provided. is there a way to change it out or add the filled elevation target head to the list of arrow heads.
my ultimate goal is to have the target symbol be at the actual location where the elevation is taken from when using the spot elevation.
2 REPLIES 2
CoreyDaun
in reply to: jledgewood409
You can create your own Elevation Target Family using the "Spot Elevation Symbol" Family Template. Once loaded into the Project, you can set this Family as the "Symbol" under Type Properties.
The list of available arrowheads can be amended (to a limited degree) under Manage tab » Additional Settings ▼ Arrowheads.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
yes and no. in regards to the limitation of the arrowhead change. that is what I would like to do. there is a target symbol given. I would like to have a different target symbol. the filled target symbol I would prefer?
