It's probably because you used the temporary hide button. It's exactly what
it's called "temporary". It's only to turn things on/off while you are
working but they will come back on when you reopen the drawing. Also, I
guess they print out too. What you want to do is to right click on the
elevation marker and select Hide Annotation In View. This will permanently
hide it.
wrote in message news:5503870@discussion.autodesk.com...
I have a few elevation tags that are sitting just outside a crop region.
Moving the crop region to the other side of the tags did not hide them. So
I used "hide objects" to hide the tags in this view.
When I printed the view, these tags also printed, even though I hid them.
Thanks in advance for any suggestions.
