good morning
am doing a work in autocad revit, and suddenly my Elevation (Buidling elevation) is gone, not available in the list
please check the attachement
i went to (1) and i found no corner was selected , so i chose the top one as in the picture
suddenly (2) has appeared, i chose the same for the other 3 (East, West,North) and it came as
elevation in point (2)
but when i click on any of them, i dont see my already levels i created (level 1, level 2 , level ceiling ... ETC)
BUT when i create "section" to view the building, i can still see my levels
is there any way to generate my old elevation again ??
best regards
Solved by constantin.stroescu. Go to Solution.
you mean you don"t see the elevation of your building even if they appear in the Project browser?
If so,try the Extents >Far Clipping..:
Your Name
what i mean :
when you open an Archi template for a work
you must see in a discipline
Elevation (building Elevation)
there are not in the project i finished
i created elevations manually , but when i click for example on East
i cant see the levels i created !!
Try using the correct symbol: building elevation. You are using interior elevations. If you click around the elevation symbol, all you are creating are views around that particular point, not elevations of the whole building. No wonder you don't see levels in some of those views, because there is no building to show at least in 3 of those 4 orientations around the interior elevation symbol.
Question: just curious: why did you say at the beginning of your first post that you were using "AutoCAD Revit" ?
I made the steps as you said :
This is exactly what I said in my first post , but more detailed..
.If it does not work ,maybe your problem is elswhere.....
Your Name
Sir
you are my hero
thanks a million, works like a charm
the view is small but it doesnt matter
thanks a million again 🙂
@Alfredo_Medina wrote:Try using the correct symbol: building elevation. You are using interior elevations. If you click around the elevation symbol, all you are creating are views around that particular point, not elevations of the whole building. No wonder you don't see levels in some of those views, because there is no building to show at least in 3 of those 4 orientations around the interior elevation symbol.
well, by mistake, for got to say REVIT MEP, and the word autocad stuck in my mind
