Elevation has gone
6 REPLIES 6
chunky2k
2510 Views, 6 Replies
Elevation has gone
good morning
am doing a work in autocad revit, and suddenly my Elevation (Buidling elevation) is gone, not available in the list
please check the attachement
i went to (1) and i found no corner was selected , so i chose the top one as in the picture
suddenly  (2) has appeared, i chose the same for the other 3 (East, West,North) and it came as
elevation in point (2)
but when i click on any of them, i dont see my already levels i created (level 1, level 2 , level ceiling ... ETC)
BUT when i create "section" to view the building, i can still see my levels
is there any way to generate my old elevation again ??
best regards
Variable Integrated Package L.L.C
Abu Dhabi - United Arab Emirates
6 REPLIES 6
you mean you don"t see the elevation of your building even if they appear in the Project browser?
If so,try   the Extents >Far Clipping..:
  • Select in plan view the black arrow from the point of the elvation mark - a blue line throucg the mark , paralel with the elevation will appear
  • In Properties >Extents >Far Clipping  set it to No Clip or Clip with Line ( if Clip with Line , then a second line will appear , showing that the clip happens before your object...strech it so to include the object inside...)
Constantin Stroescu
BIM Manager AGD
Your Name
what i mean :
when you open an Archi template for a work
you must see in a discipline
Elevation (building Elevation)
  •      East
  •      north
  •      south
  •      west
there are not in the project i finished
i created elevations manually , but when i click for example on East
i cant see the levels i created !!
Alfredo_Medina
in reply to: chunky2k
Try using the correct symbol: building elevation. You are using interior elevations. If you click around the elevation symbol, all you are creating are views around that particular point, not elevations of the whole building. No wonder you don't see levels in some of those views, because there is no building to show at least in 3 of those 4 orientations around the interior elevation symbol.
Question: just curious: why did you say at the beginning of your first post that you were using "AutoCAD Revit" ?
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
I made the steps as you said :
  • on a floor Plane I uncheck the East View pointer...a message appear that the View East will be deleted ,
  • I accept it ...the East view from Project Browser >Elevations (Building Elevation) disappear..
  • now checking again on the pointer a new view will appear called by default: Elevation 3 a
  • Right click on the name from Project Browser and change back into East (rename)
  • In floor plan click on the black pointer again...a hidden lines rectangle appears with two oposite small arrows on the left side....strech the arrows so to include the building inside the rectangle...
This is exactly what I said in my first post , but more detailed..
.If it does not work ,maybe your problem is elswhere.....
Constantin Stroescu
BIM Manager AGD
Your Name
Sir
you are my hero
thanks a million, works like a charm
the view is small but it doesnt matter
thanks a million again 🙂
chunky2k
in reply to: Alfredo_Medina
well, by mistake, for got to say REVIT MEP, and the word autocad stuck in my mind
