If I export sections to Autocad the datum level 0.00 is at -55.05 in the dwg file (see attached file)
Any idea where I can fix this error?
Many thanks
Please find the attached AutoCad file which i have extracted from your Revit File.
I am little bit strengh to show your Revit file, why the elevations are not showing in Browser. In Vigibility Graphics there is also not showing the items are active.
Thanks & regards,
Subhradeep Sen
Kolkata
India
In AutoCad how do you able to identify your level? Is this possible? I dont know actually. If you draw a line in Autocad it may be 0.000 Level. or may be other level.
Thanks & regards,
Subhradeep Sen
Kolkata
India
My project with more than 100 drawings is built on this template and I get ths error of 55m in the sections exported to dwg.
I checked project point, survey point and shared coordinates. What else can cause this error?
Thanks for your assistance
