I created a triple beam to use in this simple screened porch project. i have it installed in the model and it appears in the 3D views but not on the elevation and layouts. It appears as 1 single line. see below
3D view beam is seen.
Wheres the beam?
Solved by constantin.stroescu. Go to Solution.
if in Coarse Detail Level - it appears as a line
in Medium and Fine it will appear as you want...
Constantin Stroescu
