Electrical switches not show up in RCP
2 REPLIES 2
diesellam
4028 Views, 2 Replies
I setup my ceiling plan so that I see all of the light fixtures on my sloped ceilings.
But I can't see my electrical switches, why?
I check my VV and the electrical componets is checked for visibility.
What do I have to do to make them show up?
2 REPLIES 2
CoreyDaun
in reply to: diesellam
Have you checked the View Range? The default RCP Cut Plane is at 7' - 6", which is well above the traditional light switch mounting height. Lower the Cut Plane to somewhere below the switch.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
arnelhinson
in reply to: CoreyDaun
Hi, i also have the same problem. if edit the view range the furniture shows up
