I am using Revit 2013, and am having issues with getting my electrical to print. It shows up on the computer screen, but is not visible in the print preview, or when I print. I have gotten it to work in other files, and it prints fine on my foundation and second floor of this particular file. It only does not print for my main floor. What the heck is going on?! Any help would be much appreciated!
Solved by constantin.stroescu. Go to Solution.
if you can see on sheet but not in print and in print preview try to see if the problem can not be solved in Print Setup>Hidden Line Views Remove Lines Using: VECTOR PROCESSING <> RASTER PROCESSING . Swich between theese two settings ...sometimes it helps..
Constantin Stroescu
Thanks so much! That did the trick. I knew it was a simple thing, but had just run out of options for what I know.
