I go to the Site Settings menu, Section Graphics, chose Section cut material (Site - Earth), which opens the "Materials" window, I can see the Pattern : "Earth" in the Cut Pattern Window, which I chose to edit inside the next poping window "Fill Patterns", but I can't edit it the way I need.
Is there any way to import new fill patterns? The same way we we import model patterns from Autocad ?
I need to customize the way "Earth" is represented on our drawings, like rotating it 45 degrees.
Thanks.
