Edit wall profiles?
6 REPLIES 6
doni49
793 Views, 6 Replies
Edit wall profiles?
I have three wall segments.  I want to change the profile so that they GRADUALLY go down to nothing (or near nothing).  I attempted to do this by editing the "profile" of the walls.  But what I get is not right.
The attached image is a composite of three separate screen shots.
The first portion shows the wall in plan view.  The second and third portions are the section (that was shown on the plan view).  The first section shows what I want to do to the wall profile.  The second section shows the results of my attempt.
Is there a way to accomplish this?
TIA!
EDIT:  The image didn't look right after posting it inline.  I've also attached it as a file.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
6 REPLIES 6
awes
in reply to: doni49
Draw a reference plane that describes the top of your walls. Select the walls ->Modify wall ->Attach Top. Regards, Anders
doni49
in reply to: awes
Thanks!
That makes a lot of sense.
Don Ireland
doni49
in reply to: awes
I just tried it and the results didn't look much better.
Don Ireland
Awes reply is correct....I wonder why it didn't work for you....
I attach a screenshot with a wall cuted with a Reference Plane as Awes says (left drawing )...
Maybe  your walls a not  chaind or  joined by mitter, or disjoint ..... I don't know....
Another method can be using Boolean function using a substraction between the wall and a void component :
Architecture > Build > Component > Model in Place > Family Category and Parameters > Walls > Forms >Void Extrusion...make an extrusion  (see the attached file, right drawing) and  from Geometry >Cut  and Finish....With this method can be done not only liniar cuts but also curved or jagged...
Constantin Stroescu
BIM Manager AGD
Your Name
MKEllis
in reply to: doni49
I think your problem is that with the direction of the walls - there is no simple straight single plane cut that will produce the effect you want.
In reality, if that wall were to be built in say brick - there would in all likelihood be a flat-topped section in the triangle that is produced when two wall segments change direction. The slope needs to change direction with the wall below. I think your best bet is to make each of those wall segments separate and use [Edit Profile] to edit each segment with the correct start and end height.
Not sure how the triangular fillet would best be done - probably include it with one of the other segments and work out how much of a horizontal section is needed at the end of the profile to accommodate it.
Good luck
Martin
for Martin
Speaking from the constructor point of view you are right...in real building you never make a cut like that , but you make slope on segments of wall especialy for brick walls.
But as doni49 shows in image 2 -section - he wants a staight line cut not a succesion of sloped walls....it doesn't seem to be corect as building method for brickwork ( probably in concrete could be done ) but correct as geometrical construction  . A plane cuts a volume after a straight line in a profile view...
Constantin
Constantin Stroescu
BIM Manager AGD
Your Name
