Want to make the room number appear to the side of the room name, boxed and in smaller font size. Seems to work when I edit the family, but when applied, the box which used to contain the room number is still where it used to be; only the position of the room number itself moves.
Anyone know how to do this?
On this issue, I wanted to first verify the room box has been enabled under V/G > Annotation Categories > Show Annotation Categories in this View. This should reveal the original box lines:
Video Example: http://screencast.com/t/YTBjODk1NTg
Additionally, the existing labels \ lines are associated to a visibility parameter in the tag family types. This is set up similar to the video solution below:
http://usa.autodesk.com/getdoc/id=TS14040472
Thanks, That worked.
So how about getting that box to end up like one space to the right(or pre-determined distance) from the end of my room name field. Right now, If the room name is short, the room number is way over to the right. If the room name is longer, the box appears closer. How can I keep this distance fixed, in other words the same distance to the right from the last character of my room name, regardless of how long or short?
Make the room name label right-justified and make the room number label left-justified.
