I want to add a label to the NCS elevation tag so that I can type in a room number in the top portion of the tag, similar to adding an attribute in AutoCAD. Is this possible? I am just starting out with Revit and definately stumbling through the customization portion of the program...thanks
First, I have added the process to create an Elevation Tag is needed:
Next, keep in mind the pointer orientation as described in the following post:
Lastly, specifically for adding a portion of editable text, you can add fixed plain text to the elevation family. However the Elevation Labels are limited to the following fields [you cannot add new labels in this type of family]:
Detail Number
Reference Label
Referencing Detail
Referencing Sheet
Sheet Number
View Name
Unfortunately it is not possible to add a shared parameter or similar to allow for a custom text field [as some other family types]. I would recommend requesting this feature at the link below:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Thank you,
