When I edit a concrete slab boundary the colour is pink. When I edit a filled region boundary the colour is black. I was wondering why this is? Also, is it possible to change so that whenever I'm in a boundary editing mode the lines are pink?
When editing a floor boundary the lines are just boundary lines, they don't really have a colour or weight - that's controlled by the floor object style. When you're editing a filled region boundary they are proper line styles, so display is controlled by the line style setting (found under Manage > Additional Settings > Line Styles).
@mickyv wrote:When editing a floor boundary the lines are just boundary lines, they don't really have a colour or weight - that's controlled by the floor object style. When you're editing a filled region boundary they are proper line styles, so display is controlled by the line style setting (found under Manage > Additional Settings > Line Styles).
This is not entirely correct. Sketch lines are controlled by a linestyle found under Manage > Additional Settings > Line Styles:
