Edit Family button
13 REPLIES 13
Message 1 of 14
614 Views, 13 Replies
Edit Family button
I recieved a Revit file from some one in which, when I select the doors the
Edit family button doesnt appear in the Options bar. However, when I create
a wall and add a door to it, Edit Family button appears when the newly
created door is selected. What controls the availability of Edit Family
button?
13 REPLIES 13
Message 2 of 14
The family must be an 8.0 family before inserting. Upgraded families do not
have this option. Manually upgrade the family and reload first.
"SIS" wrote in message
news:4914473@discussion.autodesk.com...
button?
Message 3 of 14
Thanks Aaron ...
"Aaron Rumple" wrote in message
news:4914950@discussion.autodesk.com...
button?
Message 4 of 14
How do you manually upgrade a family? I'm assuming this is different from
just opening/saving with 8.0.
Fred Blome
S> "Aaron Rumple" wrote in message
S> news:4914950@discussion.autodesk.com...
S> The family must be an 8.0 family before inserting. Upgraded families do
S> not have this option. Manually upgrade the family and reload first.
S> "SIS" wrote in message
S> news:4914473@discussion.autodesk.com...
S> I received a Revit file from some one in which, when I select the doors
S> the Edit family button doesnt appear in the Options bar. However, when I
S> create a wall and add a door to it, Edit Family button appears when the
S> newly created door is selected. What controls the availability of Edit
S> Family button?
Message 5 of 14
You can batch upgrade families using a tool found here:
http://usa.autodesk.com/adsk/servlet/ps/item?id=3807894&linkID=3770375&siteID=123112
You will find instructions and the files you need at this link.
Jeff Hanson
Autodesk Product Support
Building Solutions Division
Manchester, NH
_____________________________
"Fred Blome" wrote in message
news:4918636@discussion.autodesk.com...
Fred Blome
S> Family button?
Message 6 of 14
Jeff,
thanks, but that is just for batch upgrading. It does not change the status
of the "edit" nested family button.
Fred
JHA>
JHA> You will find instructions and the files you need at this link.
JHA> --
JHA> Jeff Hanson
JHA> Autodesk Product Support
JHA> Building Solutions Division
JHA> Manchester, NH
JHA> _____________________________
JHA> "Fred Blome" wrote in message
JHA> news:4918636@discussion.autodesk.com...
JHA> How do you manually upgrade a family? I'm assuming this is different
JHA> from just opening/saving with 8.0.
JHA> Fred Blome
S>> "Aaron Rumple" wrote in message
S>> news:4914950@discussion.autodesk.com...
S>> The family must be an 8.0 family before inserting. Upgraded families do
S>> not have this option. Manually upgrade the family and reload first.
S>> "SIS" wrote in message
S>> news:4914473@discussion.autodesk.com...
S>> I received a Revit file from some one in which, when I select the doors
S>> the Edit family button doesnt appear in the Options bar. However, when
S>> I create a wall and add a door to it, Edit Family button appears when
S>> the newly created door is selected. What controls the availability of
S>> Edit Family button?
Message 7 of 14
I'm not able to download the upgrade_rfa.bat tool from that page. The error is attached in the next post. See below
Message 8 of 14
Error msg attached
Message 9 of 14
[nobr]
I finally answered my own question by looking at
Help....
src="cid:000601c59f7d$c594f850$19470105@Station13" align=baseline
border=0>
 FB> thanks, but
 FB> status of the
 FB>
Fred
 JHA>> You will
 JHA>> --
 JHA>> Jeff
Hanson
 JHA>> Autodesk
Product Support
 JHA>> Building
Solutions Division
 JHA>>
Manchester, NH
 JHA>>
 JHA>> "Fred
Blome" <
size=2>news@nospamblomeaia.com
> wrote in
message
 JHA>> How do you
 JHA>> from just
 JHA>> Fred
Blome
 S>>> "Aaron
Rumple" <
size=2>aaronrumple@hotmail.com
> wrote in
message
 S>>> The
 S>>> do not
 S>>> "SIS"
size=2>irphan_in@yahoo.com
> wrote in
message
 S>>> I
 S>>> doors
 S>>> However,
when I create a wall and add a door to it, Edit Family button
 S>>> appears
when the newly created door is selected. What controls the
 S>>>
availability of Edit Family button?
With best regards, Fred Blome.  E-mail:
[/nobr]
Message 10 of 14
aruckerY7D6L
So, what was the resolution?
Message 11 of 14
mhiserZFHXS
in reply to: aruckerY7D6L
I am continually baffled when people feel the need to comment on 18 year old threads...
Do you have this problem? If you do, I feel fairly confident in saying that whatever the solution was nearly 2 decades ago would not be the same solution today...
Message 12 of 14
aruckerY7D6L
in reply to: mhiserZFHXS
As newer versions of Revit are based on the previous ones, there is a chance that an old solution would still work. However, I did miss just how old this post was. I will continue looking and hope to find more useful responses in the future.
Message 13 of 14
mhiserZFHXS
If you're having an issue and can't find a relevant post to help you, just start a new one.
Message 14 of 14
Solution for what?
