I need to edit the Discipline Order of a drawing sheet. I can't figure out how to edit and existing entry. In ex. I have a order setup as '03 - Architectural' I want to change it to '04 - Architectural'. It will only let me add a new order, I cant find a way to delete the old one or just rename it. Any help would be greatly appreciated.
The question is not clear enough. That "discipline order" that you mention, Is it related to Browser Organization, or to a schedule of sheets?
This is an old thread, but incase anyone else needs help, I had this same thing and figured it out. Simply select all the sheets in your project browser (By holding down shift) that you want to change the disciple order. Then, in the properties window, under discipline order, just retype over it from '03 - Architectural' to '04 - Architectural' or whatever you need to change it to. It will update all of them, and since there will be no more sheets under the old discipline name then the old one will disappear.
