try to link the file again and be sure you are bringing it into the level
you are on in the import window.
Brian Earsley
www.arete3.com
18645 South West Creek Drive
Tinley Park, Illinois 60477
708.342.1250 x.225
New to DWF? Check it out!
http://www.arete3.com/services/communication.html
select "ARCHITECTURE" - "File Formats"
wrote in message news:5518953@discussion.autodesk.com...
After importing a 2007 DWG file in Revit 9.1 it is not appearing and I'm
getting the following message. I have done as recommended but still no DWG
file showing up in Ground Floor View
None of the created elements are visible in Floor Plan: Ground Floor View.
You may want to check the active view, its Parameters, and Visibility
settings, as well as any Plan Regions and their settings.
