DWG files
1 REPLY 1
101 Views, 1 Reply
DWG files
I have noticed that when I get to the third level of all my buildings I lose the DWG autocad files I have imported in. Any ideas of why they are not visible at this level and above levels?
1 REPLY 1
two things: - Make sure you import the dwg on the level you would like to use it on. Also check out the 'Current View Only' setting in the Import dialog. - If you have imported dwgs onto level 1, check the underlay and view range properties of the level 3 view. Chances are the level 3 view is not set to look down far enough. Changing these settings to include level 1 will make the dwgs visible. matt jezyk autodesk revit "jonny56" wrote in message news:14681259.1111445767142.JavaMail.jive@jiveforum1.autodesk.com... > I have noticed that when I get to the third level of all my buildings I lose the DWG autocad files I have imported in. Any ideas of why they are not visible at this level and above levels?
