DWG exported from 3ds Max Design into Revit - not visible
1 REPLY 1
529 Views, 1 Reply
Hi all!
I have some DWG files exported from 3ds Max Design 2012 and then imported (import cad) into Revit 2012. For some reason they are not visible. I have checked that the imported categories are visible. I have also tried to see if they are hiding somewhere outside cropped area. No luck...
Last time I added simple spheres next to the object and exported it again. The spheres were visible but not the actual object.
The object was made with cloth -modifier and then the poly count was reduced with ProOptimizer. I used the same method with some pillows and they work nicely in Revit.
Why won't my blanket show up? I need to figure this out...
1 REPLY 1
Never mind... I think I now have a vague idea what the problem is.  Thanks for the huge interest anyway.
