DWG export issue - Room tags
1 REPLY 1
joaopaulo
1086 Views, 1 Reply
I need to export to dwg file a floor plan containing room tags. When I try to export the plan to dwg the room tags appear all in the same layer as a text. Is there any way to avoid this. The image bellow shows the result (left) and the result that I need (right). I would like to have the tags in a diferent layer from the symbols.
Thank you,
Joao
1 REPLY 1
I am not sure I understand you very well....
When Exporting a Floor Plan , you can control Layers :
  • Application Menu (R) > Export > scroll down -Options > Export Setups DWG/DXF > Layers > Annotation Categories > Room Tags  - by default the layer is called A-AREA-IDEN (for AIA standard) . Texts are in another layer .
  • You can choose from Layer standards with specific names for them: AIA, British Standard, ISO....
  •  you can make changes as you want loading setings from another file or rename layers as you want
  • once made these options you can then Export the view...
Constantin Stroescu
