did somebody experience an issue with linked DWG which disappears arbitrarily? It is still linked and the visibility of Imported categories is set to ON, but DWG is not visible in a view. When we were linking it we set Current view only (so we can not see this DWG in other view than in the particular one).
The solution is to remove DWG and link it again but... If you have to do it every day, it sucks :(.
What may cause it is that we copied the DWG into all levels because it contains floorplans of all levels. In every level we moved the DWG into correct position and it is working for a while. We did not find a moment when it disappears :(.
Thank you.
Hard to tell what the cause might be. There are multiple reasons for an object to "disappear". Here there are some 33 reasons and some more:
http://revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons.html
This is definitely an interesting info! Thank you. Maybe the whole thing is caused be a position of a geometry in DWG which is not around the global origin.
