Revit Architecture
New Member
stevesearles
Message 1 of 4 (1,337 Views)
Driveway in Revit
1337 Views, 3 Replies
08-01-2012 06:47 PM
Is there now a standard procedure to create a sloping driveway in Revit ??
Valued Contributor
vector3
Message 2 of 4 (1,325 Views)
Re: Driveway in Revit
08-01-2012 09:49 PM in reply to: stevesearles
Welcome to the forum Steve.
Super easy to make sloped floor. Make your concrete
slab driveway, usually on the ground, and before
you finish your sketch lines, hit "Slope Arrow" on
the Modify ribbon.
Then from the center of one end of the driveway
draw the arrow to the other end.
Then just look over on the properties pallet and
see the settings for tail height and head height
and offset etc. Then click the green check on the
ribbon and you got it.
Employee
loboarch
Message 3 of 4 (1,305 Views)
08-02-2012 05:55 AM in reply to: stevesearles
A pad or a floor element can be used to create a drive if it is one element and pretty much one slope.  If you need the drive to follow contours or curve you can use a sub-region on the toposurface and then assign a different material to the subregion.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Valued Contributor
vector3
Message 4 of 4 (1,291 Views)
08-02-2012 09:43 AM in reply to: loboarch
One of the most important short videos available, must see for everyone.
Announcements
Need installation help?
