Draw circle by diameter
5 REPLIES 5
6703 Views, 5 Replies
How can I draw a circle by entering a diameter measurement instead of the default radius?  Thanks
5 REPLIES 5
Alfredo_Medina
That option is not available within the default drawing tools.Only radius.
It is possible to make a family that creates a circle with a diameter option, though.
In Revit MEP, the option for diameter is available for creating pipes, ducts, and conduits.
...now that I remember, there is an alternative for simple circles, but it needs to be used AFTER having created a circle: Create the circle by radius, then create a diameter dimension. Then select the circle, and edit the diameter dimension. (Available since Revit 2013)
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
in reply to: Alfredo_Medina
Thanks for the reply.  That's what I've been doing.
mkotsamanes
I know it has been solved but another way is to simply type "=(diameter)/2" when creating the circle
That's cool but that formula would give me a radius which default.  Is there a formula that represents the radius *2 for the diameter?
mkotsamanes
If I understand your point correctly. No there is no way (that I know of) to set the default to diameter, this method will save you the extra step of creating a dimension of the circle and changing it.
When creating the circle click the centerpoint then type " =x/2 " (where x is the diameter you want)
