Drafting View - How how to save for future use
2 REPLIES 2
octavio2
1134 Views, 2 Replies
When I save a newly created 2D detail drawn on a Drafting View in a separate folder, I also save the entire project for which it was originally intended.
How could I save that sheet only with the 2D detail so I could paste (or "import"?) that single detail into future projects without including the rest of the project where it was created?
Thanks in advance.
2 REPLIES 2
ennujozlagam
in reply to: octavio2
hi, go to project browser>pick the file>right click>save to new file.hope it helps. thanks
Jason_S
I created a new project that hosts all my drafting views that we typically use.  When I need one I use Insert from File.. --> Insert View from File to bring that drafting view into the current project.
I use this process in reverse to save newly created drafting views that we don't have in a library.  You can create a different project for each category needed.  Ex: Stair, Door Frame and so on.
Hope this helps you out.
