What is the line added in the acad.pat file to make a Drafting Pattern usable as a Model pattern?
Solved by cbcarch. Go to Solution.
You have to change it in the .pat file w/ a text editor like Notepad.
Save as, then type in MODEL where it says TYPE = DRAFTING
See attached.
Then load the Model.pat into your Material Editor/Fill Pattern.
