Please see the attached ceiling diffuser family. I would like the pattern to follow the rotation of the component when inserted onto the project. I can achieve it with model pattern but I would like to use drafting pattern because we need to show them on different scales.
The diffuser family consists of a detail family in order to show the pattern. The pattern is already set to align with object and it still does not work.
-Toan
In your diffuser you use a detailed item family.
In that family you used a filled region. That filled region has a drafiting pattern.
You might get the right result when you use a filled region with a model pattern.
These patterns normally rotate with the object.
Louis
Please mention Revit version, especially when uploading Revit files.
Sorry overlooked that part.
Maybe you could use symbolic or model lines in combination with an array and some parameter to accomplish what you need?
Louis
