Revit Architecture
Active Member
0 Kudos
Post 1 of 4
downspouts
577 Views, 3 Replies
05-10-2005 10:36 PM
I'm a newer user and would like to add downspouts in a residential project. I found a downspout profile in the library but wasn't able to add it as a component. Haven't been able to find any references to downspouts in a tutorial. Please let me know if there's a tutorial section that covers this or how to create a downspout.
Thank you.
Distinguished Contributor
4 Kudos
Post 2 of 4
Re: downspouts
05-11-2005 05:16 AM in reply to: newt
I have created a family that is a sweep path with a downspout profile, this famiy gets placed in plan around the building where I need downspouts. I created it in release 3 or 4 and haven't needed it in awhile so it could most definately be improved. Hopefully it will serve your needs or you can modify it as needed. I have included many diff files, some are commercial style with conductor heads some are residential
Active Member
0 Kudos
Post 3 of 4
Re: downspouts
05-11-2005 08:41 AM in reply to: newt
Thank you so much. This family is exactly what I needed. I have edited one of the downspouts from your family and placed it in my drawing in several places including one location with a unique path. Your files were easy to use. I can't thank you enough.
5 Kudos
Post 4 of 4
Re: downspouts
03-22-2014 06:29 AM in reply to: newt
Any ideas how to add a residential dowspout in Revit 2014?  Any 32D family available?  I checked SEEK and the one for Revit there seems to be a shape in plan only, it seems, unoless I am missing something?
Thanks in advance.
Post to the Community
New Post
